Where'd my voicenotes go?
VanBCguy
Active member
Dec 26, 2013
41
Long story short: I broke the screen on my Galaxy S3 and had to use the computer to copy and paste all the Phone folders into a new folder on my computer.
It seems I've lost my voicenotes. I can't find them anywhere in either the copied folders from the phone or the SD Card that I transferred to my new S7 Edge.
Ideas?
B. Diddy
Senior Ambassador
Moderator
Mar 9, 2012
165,518
4,662
113
Do you know for sure where those voice note files were saved? If they were saved to a protected system directory, then you can't manually copy those files to a computer.
