Re: My auto correct stop working how do I reset it.
What keyboard are you using? Has the keyboard recently updated? You can look at your recently updated list at the PS. When did you notice it stopped? Have you looked at the settings for your keyboard? Depending on the keyboard you can turn autocorrect and prediction on and off. If it updated the settings may have gotten changed. If it looks like everything is on try turning it off and on. I'd it only in your texting app? That can make a difference.
