My auto correct stop working ,how do I reset it?
A
AC Question
My auto correct stop working how do I reset it.
when I'm Texting.
Morty2264
Ambassador
Mar 6, 2012
22,922
1,053
113
Re: My auto correct stop working how do I reset it.
Go to your message settings and see what you find. What device do you have? What messaging app do you use?
VidJunky
5,603
392
83
What keyboard are you using? Has the keyboard recently updated? You can look at your recently updated list at the PS. When did you notice it stopped? Have you looked at the settings for your keyboard? Depending on the keyboard you can turn autocorrect and prediction on and off. If it updated the settings may have gotten changed. If it looks like everything is on try turning it off and on. I'd it only in your texting app? That can make a difference.
