Results 1 to 6 of 6
    Default Tap to top?
    I am currently reviewing the Android OS to see if I want to switch from the iPhone. In iOS, when you have scrolled down the screen you can tap the Status Bar on top to automatically scroll all the way back to the top. Is there functionality like this in Android?
    I have reviewed and toyed with multiple Android phones (benefits of having a friend who works for Verizon) and have not been able to find an answer to this item. I know it may seem like a trivial thing to most, but I do use it constantly.
    Thanks to all for feedback.
  2. #2
    Smitty_82's Avatar
    Android Addict
    Posts
    ROM
    ICS / Stock
    Default
    Are you talking about the app drawer or the home screens?
    Default
    For example, if I am in Safari on iOS and I have scrolled down through the web page or if I have a lengthy text conversation, I can tap the status bar on the top of the screen and it will take me automatically to the top of the page.
  4. #4
    Smitty_82's Avatar
    Android Addict
    Posts
    ROM
    ICS / Stock
    Default
    There is nothing like that native. Not sure about any of the after market web browsers though, never really had a need for that. I can see where that would bug you though if it's something your used to doing.
    Thanked by:
    Default
    Thanks for the info, not sure if an alternative browser would really solve this issue, though. It is OS wide (browser, text message app, third party apps, etc.).
  6. #6
    Smitty_82's Avatar
    Android Addict
    Posts
    ROM
    ICS / Stock
    Default
    No prob, anything else you need answers to (android wise, lol) just ask.
