How do I transfer previous downloads to my sd card?
A
AC Question
How do i transfer previous downloads to sd card?
I have a Viking pro 64 GB tablet.
dpham00
Moderator Team VP
Moderator
Apr 23, 2011
30,108
200
63
Re: How do i transfer previous downloads to sd card?
Use a file browser like solid Explorer to transfer from internal memory to sd card
AlphaTango414
3,939
95
Use the file manager of your choice. Hundreds can be found on the Play Store. Navigate to current location in the internal memory, long hold on file, find the move or cut option, then navigate to the location on the SD card you want to place it at and hit move or paste.
kirk781
