1. Soylent#AC's Avatar
    Every once in a while I glance at my phone and see a brief message like "processing screenshot." What can take screenshots without my permission?
    I do not have a screenshot app on my (standard, un-rooted) Transform. I'm wondering if there's some sort of malware involved but no idea how to even check. I do use Lookout. Could that be the culprit?
    03-22-2011 01:03 PM
  2. ls377's Avatar
    That definitely isn't normal. Have you installed any non-market apps? Or any of these apps?
    http://www.androidcentral.com/google...y-didnt-get-it
    03-22-2011 02:25 PM
  3. Soylent#AC's Avatar
    Thanks for your reply. I did not install any of the apps listed at that link. I've only installed apps from Market. I even search out firewalls and virus scanners and installed Lookout because I was trying to be careful.
    It does seem like there's something bad going on. Just no idea how to nail down what it is.
    03-22-2011 02:39 PM
  4. ls377's Avatar
    I'll see if I can find out anything else. Can you look through your apps and see if there's anything that might be suspicious? Nothing from obviously safe devs (apps from big companies, or anything that was featured on this site).
    03-22-2011 02:46 PM
  5. ls377's Avatar
    03-22-2011 02:58 PM
  6. Soylent#AC's Avatar
    I don't know what might be suspicious... I did check and I do have settings so the phone doesn't install apps from non-market sources.
    My installed apps:
    - c:geo
    - adobe reader
    - where's my droid
    - allrecipes
    - market
    - spell checker
    - appbrain
    - dejaoffice
    - voicemail
    - doubletwist
    - dropbox
    - evernote
    - facebook
    - growing degree days
    - runkeeper
    - good morning
    - shopper
    - barcode scanner
    - contacts groupu
    - launcher
    - camscanner
    - lookout
    - craigsnotifica
    - garage sale rover free
    - myfitnesspal
    - pandora
    - advanced task killer free
    - law of attraction free
    - ringdroid
    - angry birds
    - shazam
    - skype
    - socializer
    - sprint tutorial widgets
    - where
    - screenlight
    - yelp
    - sense clock and date
    - movies
    - handyconverter
    - wordpress
    - roboform bookmarklet installer
    - tip me
    - vignette demo
    - camera360
    If those all look OK, are there any "stealth" apps, like spyware or keyloggers on PCs, that could be hiding from view?
    03-22-2011 03:05 PM
  7. ls377's Avatar
    My installed apps:
    - c:geo
    - adobe reader
    - where's my droid
    - allrecipes
    - market
    - spell checker
    - appbrain
    - dejaoffice
    - voicemail
    - doubletwist
    - dropbox
    - evernote
    - facebook
    - runkeeper
    - good morning
    - shopper
    - barcode scanner
    - contacts groupu
    - launcher
    - camscanner
    - lookout
    - craigsnotifica
    - myfitnesspal
    - pandora
    - ringdroid
    - angry birds
    - shazam
    - skype
    - socializer
    - where
    - screenlight
    - yelp
    - movies
    - handyconverter
    - wordpress
    - tip me
    - vignette demo
    - camera360
    Yeah, everything looks fine. See my last post.
    If you have Lookout running, I think you're pretty much safe from hiding apps (if that's even possible).
    Are you running Froyo (2.2)?
    03-22-2011 03:11 PM
  8. Soylent#AC's Avatar
    Thanks. I'm embarrassed to admit that I don't know how to browse photos on my Transform to view any strange screenshots. The only way I know to see photos is to open the camera app, click on the last photo thumbnail, then scroll back through earlier photos.
    When I do that, I do not see any screenshots as mentioned in your link about holding down the back button.
    Is there another way to check for the screenshots, other than connecting to my pc?
    03-22-2011 03:27 PM
  9. ls377's Avatar
    You should have a "gallery" app on your phone that should pull in all your pictures. If nothing shows up in there, then connect it to your PC and look.
    03-22-2011 03:31 PM
  10. Soylent#AC's Avatar
    Running 2.1 update1.
    Don't know how I missed Gallery! Added a link to my home screen. I do have screenshots mixed into my photos. Will pay attention and see if it happens when I'm using the back button. Hope that's the cause, and not some malware or spyware.
    Will figure out how to update to froyo now...
    Thanks again.
    03-22-2011 03:43 PM
  11. ls377's Avatar
    No problem! Apparently you can do it in Froyo by pressing back + power, so give that a shot when you get updated.
    03-22-2011 03:45 PM
  12. Soylent#AC's Avatar
    Is Froyo even available for Transforms? I just tried to update Android and update firmware and it says nothing is available.
    03-22-2011 03:46 PM
  13. ls377's Avatar
    I think it was supposed to start pushing yesterday, so your number might not be up yet. Maybe someone can grab the manual update for you.
    03-22-2011 03:48 PM
