Results 1 to 8 of 8
    Default HELP how do you hook up droid to laptop
    I went to verizon and they down loaded a app to my droid (very first droid the original so it does not have wireless) they told me I had to come to this site to down load a app to my lap top and hook up cord droid to the laptop???? Cant find what to down load. Side note: I am not very tech savy
    Thanks in advave for any help
  2. #2
    mclarryjr's Avatar
    Retired Moderator
    Posts
    Global Posts
    6,544 Global Posts
    Carrier
    NOS M7 Sense 5.0
    Default
    If I'm understanding you right you just want to be able to connect your phone to your laptop. What do you need to access the sdcard?
    You shouldn't need any app just try connecting your phone to your laptop and select disk drive as your connection option (should pop up on phone when connected)
  3. #3
    rjack22's Avatar
    Posts
    Global Posts
    477 Global Posts
    Default Tethering perhaps
    Do you want to use your Droid as a modem to connect your laptop to the Internet? If so you need a data cable, drivers on your laptop for your phone, and an app to connect. I use Easy Tether.
    As stated above, if all you want to do is see and transfer files to your SD card then you don't need any software, just a driver and the data cable.
  4. #4
    tony bag o donuts's Avatar
    Resident Ringtone Maker
    Posts
    Global Posts
    7,475 Global Posts
    Carrier
    BB JB
    Default
    Welcome aboard.
    What are your intentions?
    It seems to me that the rep didn't want you to waste money paying for tethering and that you could use easy tether or pdanet.
    Default
    My son and I are headed to Arizona on a road trip and I thought it would be nice to have Internet on my lap top.So once it was hooked up I would be able to use the internet on my laptop threw the phone. need to work on google earth ect.
  6. #6
    mclarryjr's Avatar
    Retired Moderator
    Posts
    Global Posts
    6,544 Global Posts
    Carrier
    NOS M7 Sense 5.0
    Default
    You should be able to use PDA net from the market which is free to get your laptop online using your phone. After you download the app connect your phone to pc and follow the instructions from the app.
  7. #7
    Default
    I don't mean to hijack this thread but PDA Net is no longer in the
    Market. Anyone know how I can get it?
  8. #8
    Default
    Quote Originally Posted by elkslare View Post
    Does not have wireless what? The Droid has 3G, WiFi and bluetooth. What "wireless" are you referring to?
