Hello. I have the Galaxy S6 and was wanting to upgrade to Marshmallow or Nougat. But the problem is my phone refuses to update! I think it has something to do with my carrier! I use straighttalk and my phone model is SM-S906L. When I press "Check for updates" it keeps saying "Software update is temporarily unavalible". How do you FIX THIS?? I really don't want to update it the hard way by flashing roms. I'm afraid of bricking my device!
More info about my phone:
Version: 5.0.2 (Lollipop)
SE for android status: Enforcing
Baseband version: S906LUDU1AOG8
I would really appreciate it! Thanks!!
