How to turn off Whoscall popup dialog
wist
Hi, I'm not sure what I did but everytime someone calls me I get this weird pop up trying to look up the called ID and after the call I get another after call pop up (see the screenshots below). Below the pop up I see it's via app called Whoscall but I don't have this app installed so no idea how to turn it off. Can you please help? Thanks. Juro
screenshot:
http://i64.tinypic.com/n51vra.jpg
B. Diddy
Senior Ambassador
Moderator
Mar 9, 2012
165,595
4,737
113
Welcome to Android Central! It might be something that got installed alongside some other app. You may have to uninstall apps one by one until that goes away.
jagaa 796
Hi majkeey,
I was wondering, how to disable it and tried all the possible ways but no use and i came across your post and gave a try and disabled DR.SAFETY.
volaa!!! the pop is gone .
Thanks,
jagaa
nahoku
3,300
I'm rather surprised there's no option to disable this "feature". Trend Micro has been around for a long time and I wouldn't expect this from them.
fallingOutOfLoveWfithTech
