I keep getting this message on my Samsung Galaxy J7. I've looked online and the only solution I see is to change the charging port is that the only way to fix it? also what caused this to happen?
Have you actually seen reports linking water damage to a faulty temp reading? Not saying you're wrong, just not something I've seen. I would have thought it is more likely related to a temp sensor going bad, so I'd suggest using a monitoring app like Gsam to see what temps are actually being recorded.Welcome to Android Central! Any water exposure recently? This kind of thing seems to crop up from water damage.
Have you already made sure the microUSB port is clear of debris? And have you tried a different charging cable/wall plug?
The moisture damaged temp sensor could make sense.No technical reports--just an association I've noticed on the forums. Maybe the temp sensor is easily damaged by moisture?
