- Aug 3, 2016
- 652
- 1
- 0
There's been reports from several members of the forum which they describe that they are not able to delete contacts within their phone contact settings.
Select the contacts main app/icon located on the homepage/main screen. Then selected the contact which you want to delete. In this case I created a fake contact named Jason.
1) Jason's contact fate is about to come to a close. However this doesn't mean Jason wont stop calling etc.. just means his contact name has been removed from my list of contacts.
2) Selecting Jason then locating the 3 dots in the top right corner of his contact information page. This will drop down and then show several options available for this contact.
3) Selecting the "delete" option, one is then offered a confirmation notification, just to make sure you really want to delete this contact, tab delete & you're done.
If by chance your phone or the main contacts page does not offer an option to delete contacts one would have to submit a support email to the device's manufacture or reference the device's owners manual.
