right now i ping my mobile operator DNS server before sending an e-mail or if i have to do anything urgent. i am using terminal emulator [ 1.0.70 ].can i run script using terminal emulator on my android device to check periodically whether my data connection is up or down & save it in text file ?
if i can use script, where can I download it ? i just want to check for every hour for a few days.
is there any app to check connectivity periodically, if possible ability to save result in text file.
please provide suggestion or direction.
