1. osutuba's Avatar
    OK, I created a partition and ended up doing something goofball or wrong and I need to get back to a full 8GB card. Any assistance would be appreciated ...
    03-30-2011 06:34 PM
  2. osutuba's Avatar
    20 views and no responses. Thanks, guys (NOT!)
    Thank goodness for xda ...
    03-31-2011 10:11 AM
  3. Doc's Avatar
    Have you tried to use a partition program to merge the partitions you have? You can also start from scratch and delete the partitions and then recreate one 8Gb partition on the card.
    I would make sure that you do this by taking the SD card out of the phone and using an adapter to connect to your computer.
    Save whatever you have on the SD card as it will be destroyed.
    Doc
    03-31-2011 10:37 AM
  4. ls377's Avatar
    Doc
    Just to clarify, you mean the data and not the card itself, right?
    03-31-2011 10:54 AM
  5. Doc's Avatar
    The data on the card will be erased.
    There is also the possibility that your SD card can get hosed when you start messing with partitions. This can happen with computer hard drives though rarely. As for SD cards, I have not known anyone who has partitioned them so you may want to wait and see what anyone else has to say.
    Doc
    03-31-2011 01:42 PM
  6. osutuba's Avatar
    5 Words: MiniTool Partition Wizard Home Edition! I was able to get my SDCard back to full size with no partitions and my main data was saved!
    03-31-2011 06:48 PM
