Forget secret folder pin in my s7 samsung
NICKS9
3
I have the device pin also fingerprint can i change or erase the folder i have back up from this in another samsung device.
I dont want root my device,!
Please anybody help.!
You need to use whatever security you applied to the secret folder. If you used a password you can't use the device pin. These are not connected in any way. Also, if you used Smart Switch to backup you will find the secret folder is not backed up. Without the original password, you have no chance of recovering your data. To erase you need to reset the device
Thank you for help !! I apreciate that!
B. Diddy sorry for the dybpicate ...it was my mistake!
liquidsnake757
