i have a nexus 7.
recently, i can't charge it like it used to do. i tried all kinds of chargers, only one works. otherwise, even if it is plugged in, the battery will still decrease until it shuts itself off.
i also have to use a voltage monitor, i will have to plug and unplug micro-usb cable several times, before the monitor shows 1.9 v without decreasing to 0 v in less than 1 minute.
rarely, i can plug it in, and the monitor will show about 3.2 v, and charges the tablet until it is full.
when i put it in airport mode, the battery doesn't decrease its power quickly. but when i keep the wifi on, it seems that the battery decreases its power quickly.
i am guessing that the battery is dying, right? some suggested that it might be because of the bad usb port.
