At first when I set up my router (TP-Link AC1200) my phone can connect to the 5ghz network but now it won't. I could get the signal and could tap on it to enter the password, but when I press connect it only showed as "Saved, Secured" but would not connect to it.
My friend's tablet E and IPhone 7 can connect to my 5ghz network and maxed out the speed limit. Even my laptop that support ac can connect to it too so it's just my S4's problem.
I've tried various solutions I found on the net but none of them worked.
Android version:4.4.2
