Results 1 to 5 of 5
    Default Lock/password protect specific Settings?
    Is there a way or an app that will let me lock certain parts of Settings? Like if I want to allow our users to change Sound, Display, etc, but lock them out of Applications and Accounts&Sync?
    I have found a few apps that will let us password protect things on the phone, but with them if I choose Settings, then they can't change anything and I want them to have a bit of flexibility, but I have to keep them out of Applications because then they could just kill the password app that locks them out of certain apps.
  2. #2
    Moscow Desire's Avatar
    Troubleshooter
    Posts
    ROM
    Jiffy Pop Roots 3.47.114
    Default
    Quote Originally Posted by Aldar View Post
    well, you need to say why? is this phone used by different people?
    Default
    We are planing to buy android phones (LG Ally) for our employees. We want to set them up before giving them out and we don't want the employee to change certain things.
  4. #4
    Troubleshooter
    Posts
    ROM
    Default
    Hmmmmm.....There are app protection locks on the market that will allow you this,. But, if a savvy user wants to bypass this, they can go into Hboot and do horrible stuff. So, you'll have to lock hBoot as well.
  5. #5
    Default Re: Lock/password protect specific Settings?
    Can I password-protect the Settings->Apps->App Info screen programmatically using my own android app?
