A Alleycat1949 New member Mar 7, 2017 1 0 0 Visit site Mar 7, 2017 #1 I want to go back to using a pin and I am not sure how to do it.
SpookDroid Ambassador Jul 14, 2011 19,302 556 113 Visit site Mar 7, 2017 #2 It depends on which phone you have, but generally if you go to your phone's settings there should be a Security section where you can specify which lockscreen type to use.
