Ok so I admit I am a newbie, coming over to the Incredible after 3 years as a blackberry tour and then bold user. I have been looking around for the past couple of days on the forum, reading the beginner tips and tricks, apps to have, etc. I know that the pre installed apps stay on the phone unless you root. (which sucks) I understand you can't hide the apps you don't use. My question is how do the apps keep running even though I have 1) killed them with my advances task killer and 2) and also click force stop by going through settings->applications->manage applications-> clicking the app and then force stop.
The ones I have the most trouble with is cityid, skype, vcast apps, amazonmp3, Peep and a couple others. Does anyone know the cause of these apps to begin running even after killing them or making a force stop. I can literally kill an app click task killer 5 min later and half of the same list is back. Thank you for your time and help.
