Results 1 to 7 of 7
- 04-18-2011, 08:16 PM
Thread Author #1
Applications just go away!!!
Ok so I admit I am a newbie, coming over to the Incredible after 3 years as a blackberry tour and then bold user. I have been looking around for the past couple of days on the forum, reading the beginner tips and tricks, apps to have, etc. I know that the pre installed apps stay on the phone unless you root. (which sucks) I understand you can't hide the apps you don't use. My question is how do the apps keep running even though I have 1) killed them with my advances task killer and 2) and also click force stop by going through settings->applications->manage applications-> clicking the app and then force stop.
The ones I have the most trouble with is cityid, skype, vcast apps, amazonmp3, Peep and a couple others. Does anyone know the cause of these apps to begin running even after killing them or making a force stop. I can literally kill an app click task killer 5 min later and half of the same list is back. Thank you for your time and help. - 04-18-2011, 08:29 PM #2
The apps restart automatically. As useless as they are, someone decided they needed to be running all the time, so they restart when killed.
Tip: Don't bother with the task killer. If anything, it's just hurting. - 04-18-2011, 08:33 PM #3
- 04-18-2011, 08:35 PM
Thread Author #4
Thanks ls377. So is it better to just check every once in a while through the manage applications and force stop what is running? I haven't really had a problem with my battery yet, but i know it will only be a matter of time. Overall I am enjoying this phone way more than a BB.
- 04-18-2011, 08:39 PM #5
- 04-19-2011, 09:10 AM #6
Welcome to Android and Android Central! Hope you're enjoying your Incredible thus far. You can hide apps without rooting with an alternative launcher if that interests you. I know Launcher Pro will do that, ADW might. It won't uninstall them, but will keep them hidden from your app drawer.
- 04-19-2011, 05:08 PM #7
In addition to what was already said, I recommend removing the task killer. A lot of people new to Android worry about what is running in the background. Android handles it's memory very efficiently.
So remove ATK and just enjoy the phone.
Reply
