HTC Desire problems clearing space in internal phone drive.
darinasimus
Will not let me download new apps. How can i move internal memory over to sd card or can i have new downloads save to external drive when installing?
B. Diddy
Senior Ambassador
Moderator
Mar 9, 2012
165,287
4,390
113
Welcome to Android Central! You're limited to what Internal Storage the device comes with when it comes to installing apps. If your phone supports moving apps to SD, you can try that, but this feature only moves a portion of an app to the SD. Go to Settings>Apps, select an app, and see if there's a Move to SD button.
See this guide for tips on how to maximize the storage you have: http://forums.androidcentral.com/am...y-how-deal-insufficient-storage-warnings.html
Chelrie
