Incorrect storage on honor 4C
renukadissanayake
Hey, I have an honor 4C and I recently got a new Remax 32Gb sd card. So now sometimes when I try to move an app to it it gives me "not enough space" error. And so I scanned the storage with the system scanner and it shows 588GB of cache. WTF ! and so i checked the apps and sometimes Snapchat and sometimes Facebook Messenger show 1TB or 500GB as their Data. Why is this ?? But if i restart the phone its all fine.
But the problem comes randomly. I thought it was the Marshmellow update so I rolled back to lolipop. But its still there , I would be so great full if you could get me a solution. thanks
Welcome to Android Central! 588 gigabytes? Are you sure it isn't 588 MB, or 5.88 GB?
How much space is free on the SD card?
Moved this thread from the Android Apps forum to the General Help forum, since the former is intended for developers to promote their apps.
It's possible the card itself is defective (if not an outright false advertising scam). With it not being one of the major name brands, I wouldn't rule out that possibility.
Lelix2603
