I'm looking for a 2 in 1 (a solid device in that price range that can be used as a tablet & laptop) for my Dad that's under $500. Any recommendations?
2 in 1 Chromebook? Windows tablet/laptop?
As far as I know, the existing 2-in-1 Chromebooks don't have detachable keyboards -- instead, they have 360 degree hinges that allow the keyboard to fold completely back to lie against the back of the screen, effectively turning the whole unit into a tablet form.
I'm a big fan of Chromebooks, for the following reasons:
1. Lightweight OS. No endless updates like on my Windows desktop that sometimes take upwards of 30 minutes to complete the entire update process. The lack of all other system bloat also means a lesser CPU will work just fine, use less battery, and generate less heat. Google also guarantees that it will continue updates for a given Chromebook for 6.5 years, which is an insanely long period of time from a personal computer standpoint.
2. Quick bootup. It literally takes 7 seconds to boot up cold, and an additional 4 or 5 seconds for the browser to be ready to use. Compare with the 30-40 seconds on my Windows desktop.
3. Security. No antivirus needed, no constant security patches. If I lose the Chromebook somehow, I just change my Google password and a thief can't access my sensitive data.
4. Convenience. I work almost entirely within the Google space, so it's extremely convenient to access all of my files (and upload files) on Google Drive, or manage my media in Google Photos or Google Play Music (it's awesome not having to deal with iTunes any more).
Now, does that mean I can do without a Windows PC completely? Not yet, because there are always the occasional websites that require Internet Explorer (blech!), or the occasional Windows program I have to use that doesn't have a browser-based equivalent. But more and more companies are jumping into cloud or browser-based computing, which means Chromebooks gain more and more functionality. And in addition, the slow but steady introduction of Android app capability for newer Chromebooks means a quantum jump in functionality.
I would be very cautious about these cheap Windows laptops that are intended to compete with Chromebooks -- my experience with inexpensive Windows laptops has been frustrating, to say the least, in terms of performance and build quality.
Get this one by acer https://www.amazon.com/Acer-Touch-W...ag=hawk-future-20&ascsubtag=UUacUvbUpU5763103 it comes with i3-7100u, 4gb ddr4 ram, 128gb ssd, windows 10, 13.3 inch Full HD touchscreen display
same to you and if you need one with detachable keyboard than you can checkout this one https://www.amazon.com/Acer-SA5-271...ag=hawk-future-20&ascsubtag=UUacUvbUpU5764691
well those are not Chromebooks and you can get convertible Chromebook if needed but there is not one available with detachable keyboard... if you want to go with Chromebook you have to sacrifice about detachable keyboard
I'm sure Chromebooks with detachable keyboards will come at some point -- just not sure when. See this article: https://www.androidheadlines.com/2017/01/more-evidence-discovered-of-detachable-chromebooks.html
