1. Hiimliyah's Avatar
    Recently I have been using Samsung Galaxy S7 earbuds on my Samsung Galaxy Core Prime phone. It hasn't been long since I got them but, I use them every day. I have absolutely no idea what is wrong with them. Please help!!
    05-08-2017 05:39 PM
  2. Mr Mendelli's Avatar
    If they're wired, it is very likely the wire is frayed and shorting-out. How long have you had your S7? The port could also be damaged... I had issues with wired earphones if the connector rubbed against things in my pocket and flexed the wire where it connected too much or pressed on it too hard. Try moving the connector slightly to see if the left bud crackles, if it does it may be time for a new pair.
    05-08-2017 06:15 PM
  1. USB connection and my S6
    By Corbnach in forum Samsung Galaxy S6
    Last Post: 05-13-2017, 07:36 PM
  2. Screen sensitivity has been cut in half
    By AC Question in forum Samsung Galaxy S6
    Last Post: 05-10-2017, 02:48 AM
  3. LG phone says: com.android.systmui has stopped after update.
    Last Post: 05-08-2017, 09:53 PM
  4. Why my phone not ringing
    Last Post: 05-08-2017, 06:04 PM
