God! This has been bothering me for hours. I've never had an issue with the stock Samsung music player, but I just realized that if you accidentally put too many periods in the name of a song/album/artist then you can never change it back.
To go into more detail, you can change a title usually just by editing it, but if you put periods after the name then the music player won't let me reverse it. It says when I edit it that it's fine, but then when I look at it on the screen it isn't fine.
For example, I wanted "Mm.. Food" as the album name, but I accidentally put two periods at the end of the album name to make it "Mm.. Food.." which is not how I want it. It says it fine when I edit it, but it isn't. Now, I can change it to anything else in the world and it will be good, but as soon as I do "Mm.. Food" in particular it always adds the two extra dots. Itag doesn't let me change this and it really sucks because this even affects the coverart app that I use. How do I fix this?
