I am planning to root my HP 8 G2 tablet.
Reasons: 1. I want the built-in apps to be removed.
2. Hoping that I can make it faster.
I think so, but the product number is J4Y22AA.
I'm quite hesitating to do that, since it tells you that "If you disable a built-in app, other apps may misbehave". What do you think?
Also, I changed my mind I don't want to root it with KingRoot, since some people found out that there's a malware with it. Can you teach me how to root? Not using any kind of rooter like the KingRoot.
Are you concerned at all with your privacy or being hacked? Don't root.I am planning to root my HP 8 G2 tablet.
I would srtonly advise against using KingRoot. As a hacker, I don't trust it. The app hands out your devices IMEI, which comes with it's own risks. I've also analyzed the DEX of the app, and there are some suspicous scripts within...I am planning to root my HP 8 G2 tablet.
