Introduction
Groove IP makes things simple. It cuts out the need for several programs or services. You no longer need to use Google Call Back (GV callback/Voice+), a SIP Provider (sipgate) or Sip Client (sipdroid/csipsimple). The downside? It's not a totally free solution. See below for what you need.
Requirements
Google Voice Setup
Note #1: Have problems with the party not being able to hear you? Go to Settings>Troubleshooting, and enable the Audio Routing Hack.
Note #2: The app is still under heavy development.
Note #3: A update was released to help with audio routing issue's.
Requirements
Google Voice Setup
- Sign up for a account if you do not already have one. Google will give you a local number.
- Once Signed in, click the Settings Gear icon in the top right corner. Image
- Make sure your Google Voice is not forwarding to any other phones. I have mine set to forward to Google Chat/Gmail. Image
- Purchase the app and install it on your android phone.
- Sign in with your google voice account.
- There are various preferences when clicking the Settings button.
Add new settings in troubleshooting to fix call quality on some phones (If you have stuttering/choppy voice try the new Audio Processing settings)
