Page 3 of 3 FirstFirst 123
Results 51 to 70 of 70
Like Tree2Likes
  1. #51
    the2ndflood's Avatar
    Posts
    Global Posts
    1,055 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default
    That works really well. I dont like how you have to manually reconnect the app when you change from WiFi to Mobile and vice-versa, but its not that big of an issue. The app cost more then $2.99 right now, but $4.99 isn't a bad price when you consider that you will not use anymore of your carrier voice minutes when using this app. Plus a one-time cost is better then a monthly cost. So I'm impressed! Just please don't start charging a per-month fee. That would be horrible!
    Posted Using My Sprint HTC EVO3D Using Tapatalk -
  2. #52
    Posts
    Global Posts
    1,055 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default
    I'm still digging this app big time, but when I make calls over 3G, a lot of the calls tend to have static. Is there any settings in the app that would help decrease the static? Like how there is settings to fix echos. Or am I just stuck with the static, because its a network speed issue, not the apps problem?
  3. #53
    zenpunk's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Re: [GUIDE] Free VOIP using Google Voice and Groove IP
    So how well does this work with multi-tasking? Can it run silently in the background and notify you of an incoming call? Let's say I'm using mobile Winamp and listening to music and I receive a call...what does it do?
  4. #54
    AZbear's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    So far GIP has been great. However i tried it using my companies Avaya OneX call back system and when I have to enter voice mail passwords or conference call passcodes the 4 key is intercepted by Google Voice and I get a msg stating "This call is being recorded". Hit 4 again and "Recording is now off". seems to happen to a couple other keys as well.
    Anyone have this setup?
    Thanks
  5. #55
    Posts
    Global Posts
    1,055 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default
    Does anyone else here have the Talking Caller ID app installed on their phone, along with this app? Does the Talking Caller ID app speak while your making a call using GrooVe IP? Mine does and I don't know how to stop it from happening; besides turning the Talking Caller ID app off altogether.
  6. #56
    dennis mcgean's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Question Re: [GUIDE] Free VOIP using Google Voice and Groove IP
    is it possible to receive calls to my cell number using groove ip ? Or do the calls have to be made to
    my GV number only for them to go to groove ip ?
  7. #57
    greene1014's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    You need to enable chat!
    dennis mcgean likes this.
  8. #58
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I have chat enabled - outgoing calls can be made thru G IP - all incoming calls to my cell number go
    directly to T-Mob Wifi - only incoming calls using my GV number go to G IP - I think this is just the way
    it is - I was hoping there was a way to get the incoming calls to my cell number to go thru G IP too.
    Thanks for your reply - I'm not a techie so all input is appreciated.
  9. #59
    FlyingBoat's Avatar
    Posts
    Global Posts
    9 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by dennis mcgean View Post
    To do what you want, you could port your cell phone number to Google Voice, then get a different number for your cell phone. That way all calls to your old cell would go through GV. Of course you would want to check with your carrier so you don't get ETF.
  10. #60
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by RonBonnell View Post
    We will have to start giving out 2 numbers either way - which is not terrible - we were lucky enough to get
    a GV number only one digit different from the cell number so this can work out - I don't want to mess
    with the porting issue - it's two numbers both ways so we'll try it out this way - still a useful app -
    thanks for your input
  11. #61
    slikkk's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    How much battery does it consume when constantly on?
  12. #62
    Posts
    Global Posts
    1,055 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default
    Quote Originally Posted by slikkk View Post
    Not too much, but each phone is different.
  13. #63
    slikkk's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default
    For some reason, the person on the other end keeps getting echo even with echo cancelling checked.
    Sent from my SGH-T959 using Tapatalk
  14. #64
    Xine-'s Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    This thing about Flurries.com true?
  15. #65
    vlstaele's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Thanks for the tips! The trick was to follow your instructions not to have any other forwarding numbers besides the google chat/email. Once I did that it rings through just perfectly!
  16. #66
    dkd711's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Go into google voice app settings on your phone and select "Do not Use Google Voice to make calls" Groove Ip already does this for you. Now try again to see if you get incoming calls. This worked for me on EVO Shift.
  17. #67
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by dkd711 View Post
    Thanks for the input - I can't find that setting in the G IP app settings - is it down under a higher level option ?
  18. #68
    prabee's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    found 1.2.10 apk free...can i use this?
  19. #69
    Posts
    Global Posts
    1,055 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Why has no one fixed the issue where the "Talking Caller ID" app runs while making calls through Groove? When I make calls using your app, the Talking Caller ID app reads out the name of that contact, as the call is being made; which is really annoying. Can someone please prevent this from happening?
    Sent From My Sprint HTC EVO3D Using Tapatalk ---
  20. #70
    rr4jim's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I have two issues with the setup on my Nexus4 that I've not been able to resolve and hope someone can help.
    1. I've not been able to find the correct combination of settings such that a call to my Google Voice number rings my Nexus4 without using plan minutes. As I'm on the t-mobile $30/month plan with only 100 minutes, this will be a problem.
    2. When I receive an incoming call, my Nexus4 screen goes black until the call is terminated on the other end. I've adjusted my setting to lengthen the amount of time before the screen sleeps, but this does not appear to be the issue and it didn't resolve the problem.
    Help and suggestions greatly appreciated!
