Results 1 to 3 of 3
    senote's Avatar
    Posts
    ROM
    CM9
    Default Sync an ipod with my android
    I have an Android phone (Nexus S) and a tablet (Xoom) and an iPod touch. What I want to know is this. Is there a way I can put my music on the Xoom and then sync my iPod touch to it?
    I don't want to use the phone because the battery life isn't good enough, the ipod I can charge once a fortnight, the phone I charge daily and it wouldn't make it through a working day if I use it for my music.
    So does anybody know an app that will do this?
  2. #2
    ross.lafferty's Avatar
    Posts
    ROM
    GingerBlur 4.5
    Default
    Huge pet peeve of mine from my old iPhone. On my droid I can wirelessly sync my music from my iTunes library with iSYNCR, but I always had to hook my iPhone up to the PC to actually sync. You would hope by now apple would embrace wireless syncing.
    Long story short, iSYNCR could keep your XOOM in sync with iTunes and then you could manually manage your music over to your iPod from there. Not ideal, but its a thought.
    senote's Avatar
    Posts
    ROM
    CM9
    Default
    Thanks for the response, I see how iSYNCR can get my itunes music to my Xoom but would my iPod touch need to be jailbroke for me to copy the files over?
