Results 1 to 4 of 4
- 05-19-2011, 09:25 AM
Thread Author #1
Caller's picture
I have a stock EVO 4G. I've changed the picture of a contact on both my phone and via the Google contact manager (website).
Is there a way to force the Google Contact image to show up when the person calls (as opposed to their Facebook or twitter picture)? It seems like this should be a simple enough request but I can't find a solution for it.
Thanks in advance... - 05-19-2011, 09:30 AM #2
Check the contact or facebook or twitter settings to see if there is an option to disable the photo from showing.
- 05-19-2011, 09:42 AM
Thread Author #3
I see a setting similar to that for the twitter app but not for the facebook app...
thanks for the suggestion. - 05-19-2011, 12:31 PM #4
Try removing the account from the Facebook app and sign back in but make sure to uncheck "sync to contacts".
Reply
