Results 1 to 10 of 10
    IamJAd's Avatar
    Posts
    Global Posts
    186 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Can't delete a contact - HELP!
    Ok, so...all my contacts are syncing from Google. All is fine.
    I wanted to bring a business card in as a contact, so I took a picture of it via Google Goggles, made sure all the info looked good, and saved it as a contact. I guess I didn't say to save it to Google, since it never showed up on my Google account online.
    When I search for the contact, it says it's a "phone" contact. It doesn't give me an option to delete it. If I scroll alphabetically to find the contact, it doesn't show up at all (first or last name). If I look to hide all my Google Contacts, it doesn't show, nor are there any contacts saved to the phone.
    How the heck do I get this contact off my phone?? This one has me puzzled.
  2. #2
    vbonura's Avatar
    Posts
    Global Posts
    6 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default
    I'm having the exact same issue. It seems that goggles is saving the contact to the "phone" contacts. it doesn't show up in my gmail contacts and the only way to find it is to search contacts but like you said you cannot delete or move to gmail contacts. doesn't make sense
    thunderbolt
  3. #3
    DenverRalphy's Avatar
    Posts
    Global Posts
    5,312 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default
    To fix it, I usually just log into gmail from a desktop/laptop. Go to contacts, select Other Contacts, select the contacts in question, then click the Add To My Contacts button.
  4. #4
    DarkBeer's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default
    Having the same problem as well. Can't find a way to delete the contact that was scanned via Google Goggles. Logged into my Gmail account and looked for other contacts, but it isn't there. Uninstalled Goggles and the contact is still there. One other thing that I noticed is that the contact is listed and then under the name it shows "HTC weather sync provider". My other contacts show Google or Exchange, so I'm assuming this might be part of the issue.
  5. #5
    Moscow Desire's Avatar
    Troubleshooter
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Jiffy Pop Roots 3.47.114
    Default
    Quote Originally Posted by DenverRalphy View Post
    Sounds good to me. Exactly....
    If it works for you, give thanks to the above poster.
  6. #6
    DarkBeer's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default
    I went to the market and downloaded Contact Remover from HolyHog Software and I was able to use it to remove the contacts I added with Goggles.
    IamJAd likes this.
    IamJAd's Avatar
    Posts
    Global Posts
    186 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default
    That app worked great! Thank you!
  8. #8
    etsch's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Re: Can't delete a contact - HELP!
    Thanks for the tip. HolyHog did not work but Easy Contacts Delete did the job on my HTC M9.
  9. #9
    Umesh Shankara's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Contact remover helped me to delete contact,
    but this is a flaw in Andriod which has to be fixed
  10. #10
    Ned D's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Is the Contact still in "Circles" or someplace else?
