When someone calls and they don't have a picture and the Android man shows up... is there anyway to change that? I really would like to change it to this picture.
I was in the same boat as you. I was concerned I'd mess things up. I've rooted and unrooted a few times....my android isnt rooted and i dont plan on rooting it cause im to scared i will mess it up and wont be able to fix it.
I will give it a look... But still nervous as hell about rooting. There are only a few things as of right now that rooting would help but no enough for me just yet to mess with.. But thanks for all the help !
If you are worried about rooting wait it out for a while until development catches up and an easier method to root is released.
