Results 1 to 4 of 4
    Sonic132's Avatar
    Posts
    ROM
    Original (so far)
    Default What is with my mp3s?
    I have a Samsung Epic that I recently connected to my laptop and transferred my favorite tracks onto. Well now none of my phones apps can play them. I thought maybe it was an unsupported format. So I installed Winamp and a few others. But still no luck. I just don't understand it.
  2. #2
    Default
    You're sure they're MP3's? How, exactly, are they encoded? What happens when you try to play them? Any error messages?
    Sonic132's Avatar
    Posts
    ROM
    Original (so far)
    Default
    Well it must have been a software issue. Because I got rid of some apps and now they play.
    Still have an issue with swype not getting a lot of the words right. I have to keep going back and fixing everything. Any way of going into the words it's learned and fixing them or adding more?
    Sonic132's Avatar
    Posts
    ROM
    Original (so far)
    Default
    Ok, it gets weirder. Sometimes if I restart my phone then it works. Also, sometimes if I close all my running apps that fixes it. Perhaps it's a ram issue?
