Results 1 to 4 of 4
- 06-06-2011, 02:23 AM
Thread Author #1
- 06-06-2011, 07:15 AM #2
Whose voicemail are you using? Voicemail isn't a phone feature. It's either a feature from your carrier or another voicemail service. The options available to you depend on the voicemail service that you're using.
- 06-07-2011, 11:14 AM
Thread Author #3
- 06-07-2011, 07:49 PM #4
From what I was able to tell by reading about VZW's Basic, Premium and Visual Voicemail plans, the ability to upload a sound file as your greeting is not available through them.
Some say that his dormant chips were left that way for YOUR SAFETY... Others say that once "turned on," he can not be turned off... All we know is... He's called The Stig.
Reply
