Results 1 to 2 of 2
- 06-20-2011, 07:48 PM
Thread Author #1
Samsung Intercept... will it fit my needs?
Until now I've only had prepaid basic phones(Tracfone, PayGo), but I'm thinking of switching to the $25/month Virgin Mobile plan.
I also lost my iPod Touch recently, and am looking for a phone that has mp3 and web capabilities.
I'm totally new to the Android world and feel intimidated by all the clashing opinions.
I've been seeing a lot of negative reviews for the Intercept saying that the Optimus V is better, but I really like the slide-out QWERTY keyboard. I'm not going to be using a ton of apps and don't mind waiting a couple of seconds, so is it worth it to go with the Intercept for its keyboard?
My uses will be:
- Calls
- Texting
- Music
- GPS
- Email
- Netflix (would there be lag on videos?)
- Facebook
If it can perform these functions efficiently and effectively, I think I'm going with the Intercept. I plan to upgrade to a 16GB card for my music.
Also, I found some people saying it can't handle Angry Birds. Is this true? That's probably the only game I'd get, but I can live without it.
EDIT: The Intercept is on sale right now for $150, so price isn't a factor. - 06-20-2011, 08:55 PM #2
I think you will be happy with the Intercept. It has a faster processor that will handle apps fine. It seems like you want a keyboard so that is a plus. Just be warned., you're forecast uses from the device will change once you use a smart phone
. You'll use it more intensely when you settle down with it.
I've used an Optimus S and like the Optimus line. Personally, I would settle for an Optimus, but that's personal preference.
Don't forget to check back in to update us on your choice.
Reply
