Results 1 to 10 of 10
    Dankees's Avatar
    Posts
    Global Posts
    210 Global Posts
    Question How To Factory Reset My Android 2.2 Tablet
    Can someone please tell me how to do a Factory Reset on my Android 2.2 tablet?
    There are no options in the settings menu.
    I believe it may be a GPad GForce tablet - it's from China.
  2. #2
    Moscow Desire's Avatar
    Troubleshooter
    Posts
    ROM
    Jiffy Pop Roots 3.47.114
    Default
    Uh cha wang, chee ma chee ka.
    Ok, you should be able to boot to the recovery menu.
    Now, bear in mind, most folks here are phone users. The tablet numbers are climbing.
    However, it should be relatively the same in a sense.
    Usually, it involves turning the power off (shutting down) then, holding the Volume button, and hitting and holding the power button, it should boot to recovery.
    Now, this method should be similar. But check google "boot to recovery xxxxx (tablet model)"
    Then from the recovery menu, you should be able to navigate to Reset/system reset/system restore
    Thanked by:
    Dankees's Avatar
    Posts
    Global Posts
    210 Global Posts
    Default
    I held down the volume button, then I pressed the power button - nothing happened. :-(
    Now what?
  4. #4
    Troubleshooter
    Posts
    ROM
    Default
    Do a search for recovery on your specific tablet. Like I said, a lot of devices are different.
    Thanked by:
    Dankees's Avatar
    Posts
    Global Posts
    210 Global Posts
    Default
    I'm not even really sure what tablet I have. I think it's a GPad GForce.
    Is "Recovery" also a factory reset? How dangerous is it to do?
    Thanked by:
  6. #6
    Troubleshooter
    Posts
    ROM
    Default
    Quote Originally Posted by Dankees View Post
    Recovery is a menu system. Sort of like system tools. Hopefully there, you will find an option similar to Factory default, or original settings.
    Note that doing this, will set your tab to the condition it was when shipped. So it's best to backup your contacts or such. Usually this does not effect the SD card, but it's always wise to back that up also.
    You will lose however, any apps you downloaded.
    Dankees's Avatar
    Posts
    Global Posts
    210 Global Posts
    Default
    Is "Recovery" an application?
    Do I need Root Access? If so, how do I do that? I am a novice.
    Is this what I need or is it something else I need?
  8. #8
    Troubleshooter
    Posts
    ROM
    Default
    Being a novice, is not an issue.,
    But, you need to know what you are buying, before you make the purchase.
    If you wanted to save a few bucks, by buying a cloned chinese tab, well, lesson learned.
    Tomorrow, I'll do a little searching, and see what I can dig up on your tab. You may want to pop the battery cover off, and give any applicable numbers. Like model number, manufacturer, serial number, and FCC number.
  9. #9
    Default Re: How To Factory Reset My Android 2.2 Tablet
    Turn tablet off and push menu and power.
  10. #10
    I just got the 7 inch tablet android from ebay from china. and it is stuck on the android logo.I tried all the suggestions and nothing working.
    couldn't find the little factory hole button either..... help ???
