Results 1 to 5 of 5
- 06-24-2011, 12:32 PM
Thread Author #1
Does the built in web browser support APK installation?
I'd like to know if I can access an url directed to an .apk file on my Android device through the built-in browser and have it launch the install screen when downloaded.
Seems like it would be much easier to do than put it on an SD card and use a file explorer to install an app, - 06-24-2011, 12:34 PM #2
- 06-24-2011, 01:44 PM #3"Some see the glass as half-empty, some see the glass as half-full. I see the glass as too big."
- George Carlin - 06-24-2011, 03:46 PM #4
Re: Does the built in web browser support APK installation?
You will need to download the .apk and access it from the sd card. Use a file explorer to find it, select it, and install it. Make sure the box is checked in application settings to allow non-market installation.
- 06-24-2011, 04:51 PM
Thread Author #5
Reply
