Results 1 to 7 of 7
    Default ringtone help 4 pantech cross over
    i just got this phone and i down loaded a ringtown and it saved 2 my music player and cant and dont know how 2 set as ringtown. . . . . . . if some one can help me step by step that would be grate. . . . . .
  2. #2
    Default Re: ringtone help 4 pantech cross over
    If it doesn't exist, create a Ringtones folder on your SD card. Move the ringtone into the Ringtones folder.
  3. #3
    Default Re: ringtone help 4 pantech cross over making folder
    Quote Originally Posted by takeshi View Post
    Yes, but how does one do that on the phone??? I want to make a folder for certain photos, but don't know how.
  4. #4
    pazzo02's Avatar
    Posts
    Carrier
    Sabsa Prime ICS
    Get a file manager from the Market Play store. Astro is a good one. That will allow you to browse your SD card and do things like adding folders and moving files. You could also just connect to a computer and access the SD that way, but the file manager is just easier.
  5. #5
    how do i get free ringtones my carrier is airfire
  6. #6
    Devinator's Avatar
    Sūpā Saiya-jin Fō
    Posts
    Global Posts
    4,376 Global Posts
    Carrier
    Stock/Stock/CM9
    Do you have music? Then you can use them as ringtones. I like to crop songs and use them as ringtones.
  7. #7
    Quote Originally Posted by porscha View Post
