Results 1 to 5 of 5
    whiplash473's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Droid X2 Root... What's going on?
    Hey guys, I'm using z4root to root my DX2 and the app keeps crashing half way through the installation, I've tried a regular reboot and took the battery out but it's still doing it. Any suggestions on something else that might help me out?
  2. #2
    lgwhitlock's Avatar
    Posts
    Global Posts
    5 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Re: Droid X2 Root... What's going on?
    I am not sure that Z4 can be used on the X2. From what I have read you need GingerBreak. You can more information in the forums at http://forum.androidcentral.com/moto...ipped-rom.html
    Leland
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Can I use that even with Froyo?
  4. #4
    srkmagnus's Avatar
    Posts
    Global Posts
    13,761 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Stock 4.4 (KitKat)
    Quote Originally Posted by whiplash473 View Post
  5. #5
    srkmagnus's Avatar
    Posts
    Global Posts
    13,761 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Stock 4.4 (KitKat)
    It might not work. There was a patch in Froyo that closed the hole apps were using to gain root access. The Gingerbreak app says it might root Froyo devices.
    If you are still on the shipped ROM, see here: [How-To] Root the Droid X2 (shipped ROM)
Tags for this Thread
