1. whiplash473's Avatar
    Hey guys, I'm using z4root to root my DX2 and the app keeps crashing half way through the installation, I've tried a regular reboot and took the battery out but it's still doing it. Any suggestions on something else that might help me out?
    06-29-2011 02:27 AM
  2. lgwhitlock's Avatar
    I am not sure that Z4 can be used on the X2. From what I have read you need GingerBreak. You can more information in the forums at http://forum.androidcentral.com/moto...ipped-rom.html
    Leland
    07-08-2011 01:01 AM
  3. whiplash473's Avatar
    Can I use that even with Froyo?
    07-13-2011 05:36 PM
  4. srkmagnus's Avatar
    07-13-2011 09:05 PM
  5. srkmagnus's Avatar
    It might not work. There was a patch in Froyo that closed the hole apps were using to gain root access. The Gingerbreak app says it might root Froyo devices.
    If you are still on the shipped ROM, see here: [How-To] Root the Droid X2 (shipped ROM)
    07-13-2011 09:09 PM
