1. N3XUS11's Avatar
    ok I was using MIUI then i saw the beta for a CM 9 rom, so i thought ill try it, i was going to do a backup and a factory reset, but when i looked i saw formatting and i was not sure if i actually checked back up and wipe in Rom manager and if i kept wipe devic checked, so i pulled the battery to start over but now my stuck on my boot screen.
    Does my Phone have a rom on it and if not how can i fix it , i dont now how to get to recovery am only able to get to Stock Recovery, PLEASE HELP-X
    08-22-2012 09:14 PM
  2. Johnly's Avatar
    Can you sbf it?
    08-22-2012 09:19 PM
  3. N3XUS11's Avatar
    Whats That? i this is the first time i had a issue
    08-22-2012 09:26 PM
  4. jean15paul's Avatar
    Pulling out a battery while in bootloader or recovery always scares me. I wish I had an answer for you, but I'm not that smart. I'd probably asked in the DroidX forum though.
    08-23-2012 01:33 PM
  5. N3XUS11's Avatar
    I went moments after posting this , they helped me out , SPFing was not as hard as I thought
    Sent from my DROIDX using Android Central Forums
    08-30-2012 05:39 PM
