1. Marten112's Avatar
    Hi guys,
    I don't know if this is the right forum for my question. I am experiencing an annoying issue with WiFi on my Nexus 7. Since day one it is running perfectly smooth but since this morning it actually is making me very angry. I have these Apps, Tasker and Llama. Llama is making sure WiFi is turned off between 11pm and 7am. For some reason I have to turn on WiFi manually. No issue with this. It has become a morning ritual by now.
    But since this morning WiFi is acting really strange. It basically does something like this:
    • I turn on WiFi
    • It starts scanning
    • It finds the usual amount of WiFi spots
    • It starts connecting to my home WiFi network
    • It start verifying
    • It starts verifying
    • Its starts verifying
    • It finds less WiFi spots
    • It finds only my home WiFi network
    • It starts verifying.
    • It finds noting at all
    I know the list above sounds weird. But that's basically what I see on my WiFi settings screen. Anyone knows what could cause my Nexus to bail on all WiFi spots?
    I already shut down both Tasker and Llama and restarted my Nexus 7.
    Thanks for any help.
    Marten
    11-16-2012 03:04 AM
  2. Lonelydad's Avatar
    Have you checked your Jellybean status? I got my upgrade to 4.2 a couple days ago, and you might have gotten yours. If so, you need to check if your two apps are compatible with 4.2. Try uninstalling them and see what happens to your WiFi.
    11-17-2012 01:23 PM
  1. Samsung Galaxy Nexus, Wifi, Geolocation issue
    By hedbert in forum Sprint Galaxy Nexus
    Last Post: 10-09-2012, 11:38 AM
  2. Nexus One Wifi issues after unlocking bootloader
    By keith.randy in forum Google Nexus One Rooting, ROMs, and Hacks
    Last Post: 11-28-2010, 06:36 PM
  3. Wifi issue after reset
    By Crowfoot in forum HTC Droid Eris
    Last Post: 03-02-2010, 03:01 PM
  4. Droid Eris WiFi Issue with Mixed Router Signals
    By ridavid81 in forum HTC Droid Eris
    Last Post: 01-02-2010, 09:09 PM
  5. WiFi Issues
    By VDubb22 in forum HTC Hero
    Last Post: 01-02-2010, 01:01 PM
