Results 1 to 4 of 4
    Rizz1-2's Avatar
    Posts
    Global Posts
    353 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default LTE Radio's
    I have been seeing articles here and there about how smartphones are able to better utilize LTE while being more and more efficient in the battery department. My question is, how hard is LTE on a battery? If you have good signal strength on LTE will that drain your battery super fast, or is it switching between 3g/4g and searching for the LTE that really does the damage? Is there any comparisons out there? If anyone could post a link or any sort of resource I could read through that would be awesome. I just wanna understand it a little better. Thanks!
  2. #2
    trunks527's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Re: LTE Radio's
    Quote Originally Posted by Rizz1-2 View Post
    I know for a fact on my Galaxy Nexus I can go from 99% to 91% on 5 hours of standby with LTE on and staying consistent. This was with the 2100 extended battery. But everyone complains about lte draining battery. If it's searching you're done. I suggest if you're in a no data area just turn mobile data off. Just my 2 cents though.
    Rizz1-2 likes this.
  3. #3
    Shadowriver's Avatar
    Posts
    Global Posts
    704 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    It all depends on LTE modem in device, in theory there can be even more efficient LTE devices
  4. #4
    enik's Avatar
    Posts
    Global Posts
    1,004 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Gingerbread Deck, Matrix
    It depends on the device. My bionic drains battery like no ones business and thats in a good 4g area, my nexus will drain slightly faster on 4g maybe 1.5% per hr and on my gs3 I haven't noticed any appreciable difference in battery life. The gs3 does have a more efficient radio and I think in the case of the bionic and nexus it is really an issue of manufacture implementation seeing as the hardware is almost identical.
    Sent from my DROID BIONIC using Tapatalk 2
  1. why isn't there a GN with GSM and 4G LTE radio?(like the new iPad
    By Touchpaddle in forum Verizon Galaxy Nexus
    Last Post: 04-10-2012, 06:30 AM
  2. Let's push CNN to investigate the LTE Radio issue
    By DiamondDave in forum Droid Bionic
    Last Post: 12-30-2011, 01:40 AM
  3. Samsung LTE Radio - FCC
    By nemov in forum Rumored Devices Lounge
    Last Post: 09-21-2011, 04:51 PM
  4. same LTE radio as TB, Charge, Revolution?
    By jdg1 in forum Droid Bionic
    Last Post: 09-01-2011, 05:40 PM
  5. What model is the LTE radio?
    By beveritt in forum Verizon Droid Charge
    Last Post: 05-13-2011, 06:56 PM
