1. beantown861's Avatar
    Hey everyone, I've had a Droid 3 for about two years and it's always worked alright. However, just recently I noticed that when using the camera, if I ever choose the direction in which the camera is shooting (for instance, if im holding the camera I can take a picture of what is in front of me like the beach, but I cannot take a picture of say, myself), then I have the message "camera is unable to initialize". I'm sure some of you know what I'm talking about. It's basically when you hold the camera in front of you but you cannot the vision of the camera, either something in front of you, or what is looking into the camera. I've tried taking out the battery and clearing the data but for some reason, I cannot change the viewpoint of the camera--when I change it so for instance I'd be taking a picture of myself it just stops working.
    11-23-2012 04:03 PM
  2. patfactorx's Avatar
    Try doing a factory reset or flashing another rom. Usually fixes most problems.
    Sent from my DROID4 using Tapatalk 2
    11-23-2012 05:42 PM
  1. Front facing camera does not work...
    By BigJonMoo73 in forum Verizon HTC Thunderbolt
    Last Post: 12-02-2011, 06:32 PM
  2. Camera app does not work while on call!!!
    By hotis300boy in forum Sprint Epic 4G
    Last Post: 09-22-2010, 05:03 PM
  3. Evo and blueant q1 a2dp does not work!
    By njfoses in forum EVO Accessories
    Last Post: 06-18-2010, 11:30 PM
  4. !!Home key does not work in Launcher Pro!!
    By ardieilardi in forum Android Apps
    Last Post: 06-10-2010, 01:16 PM
  5. Wifi does not work
    By alphabets in forum Motorola Droid
    Last Post: 01-04-2010, 09:50 AM
