Can someone help me with connecting ps3 controller with S3?
Now that im finally rooted you can obviously do quite a lot with your phone, im rooted stock ROM 4.1.2 jelly bean and I have the siyah 1.8.6 kernel installed. I dont want to buy a usb on the go cable I just want to connect my s3 and a ps3 controller wireless. Has anyone got a tutorial? Thanks.
Re: Can someone help me with connecting ps3 controller with S3?
Odp: Can someone help me with connecting ps3 controller with S3?
I know ps3 have wierd unstanard init seruence which make it need special driver, but i think its possible. I will try to scout on this topic since i got new tablet it might be useful.
Okay then mate, I have an xbox but not wired controller and I that doesnt work on wireless, so im using my dads ps3 but I can't use the controller wireless on my s3
You can connect ps3 to pc via standard bluetooth :) so i dont think it would a problem once you make it work
Re: Odp: Can someone help me with connecting ps3 controller with S3?
For a PS3 controller, I'm pretty sure you need to download Sixaxis Controller to link them up, and once you buy that app, it explains how to set it up. I had to do this for my TouchPad, note that it also changes the BT address so you are unable to use the controller with your PS3 until you set it back to something your PS3 will recognize.
