1. RavenSword's Avatar
    So I really want to give this service the proper chance. I signed up for the special pricing and everything. But honestly, there's one thing I'm noticing that's bugging me compared to my experience with Rdio in comparison. See, on Rdio the quality was always good or at least clear. On google music however, unless im on high settings in bandwidth management, it does not sound very good. In fact, it sounds like when I stream YouTube audio via data 3G. IE not very good.
    I tried uninstalling the app and redownloading it's data, but it's still the same. So I'm thinking this is just how it is. But if Rdio can make it sound good via 3G with no excessive bandwidth, why can't google?
    Am I the only one noticing this? On wifi it sounds fine.
    07-02-2013 03:41 AM
  2. Scott Kenyon's Avatar
    No matter what settings you use, the app will default to the quality it can manage with your connection speed. Sounding great would more than likely cause buffering, which is why you're getting the inferior quality.
    Sent from my HTC One using AC Forums mobile app
    07-02-2013 08:42 AM
  3. RavenSword's Avatar
    Then is it best to always keep it on low or normal?
    Honestly, I want it to sound good, but my data plan can't handle high quality like it was prior to the update.
    07-02-2013 11:18 AM
  4. devinakbv's Avatar
    07-03-2013 02:58 AM
  1. unlimited data in the future for all?
    By slik6996 in forum AT&T
    Last Post: 08-16-2013, 09:05 AM
  2. Replies: 1
    Last Post: 07-02-2013, 01:39 AM
  3. open notebook on android
    By Vivian Chao in forum Android Apps
    Last Post: 07-02-2013, 01:21 AM
  4. Uninstall 4.1 update on my lg optimus l9
    By hoopie444 in forum Android 4.1 / 4.2 / 4.3 Jelly Bean
    Last Post: 07-02-2013, 12:26 AM
  5. On CM 10.1, having a weird problem, err problems..
    By PittsDriver in forum HTC One Rooting, ROMs & Hacks
    Last Post: 07-01-2013, 11:47 PM
