Results 1 to 6 of 6
    Default Volume pops-up when i receive a call
    Hi
    I have Samsung Galaxy Note II
    Every time i receive a call, the volume option pops-up
    Anyone knows how to fix this?
  2. #2
    Default Re: Volume pops-up when i receive a call
    I'm not sure if this is what you're referring to:
    1. Open the phone
    2. Go to "Call Settings"
    3.Scroll down to "Use extra vol. for calls" and uncheck
    thanks for the response.
    sadly it doesnt fix the issue. Maybe i havent explained it properly
    When i receive a call, the volume meter pops-up when i answer, and the volume is set aprox to 75%
    When i end the call, the volume meter pops-up and the volume is set to 0%
    After that, when i try playing a video, i get no sound and i always need to adjust the volume.
  4. #4
    when I receive calls my volume pops up and also when I end calls it pops up on my galaxy s3 anyone no how to fix this issue?
  5. #5
    Only thing I can put forward is to back up all your data and do a factory reset.
    Thanked by:
  6. #6
    srkmagnus's Avatar
    Posts
    Global Posts
    6,777 Global Posts
    ROM
    Stock 4.4 (KitKat)
    Quote Originally Posted by Duncan1982 View Post
    That's what I'm thinking as well. I can't see what would be causing the volume to automatically increase its volume upon answering or ending a call.
    Thanked by:
  1. G Pro does not boot/charge. Menu+Back button flashes when on USB
    By Bram vd vecht in forum LG Optimus G Pro
    Last Post: 12-29-2013, 11:31 PM
  2. Replies: 1
    Last Post: 12-10-2013, 10:13 AM
  3. Volumes Jumping to Zero
    By EJonline609 in forum Virgin Mobile Optimus Slider
    Last Post: 12-08-2013, 11:58 PM
  4. Replies: 0
    Last Post: 12-08-2013, 08:34 PM
  5. Q: Record phone calls
    By trpenner in forum HTC One X
    Last Post: 12-08-2013, 08:01 PM
B
