Results 1 to 3 of 3
    Default HELP! Dropped my Nexus 7 and now it won't turn on?
    I dropped my Nexus 7 and now it has a crack on the top right corner of the screen and now it won't turn on. The damage doesn't look TOO extensive, though, so I opened it up and checked the inside. There seems to be no internal damage, and I made sure the battery was plugged in nice and tight. But it still won't turn on! I tried to charge it, but the screen will only flicker on and off. Is there anything I can do? Surely it can't be completely broken, it was just one drop that only damaged part of the screen...
  2. #2
    Haalcyon's Avatar
    Posts
    Global Posts
    6,219 Global Posts
    ROM
    CM 10.2
    Default Re: HELP! Dropped my Nexus 7 and now it won't turn on?
    I'm no double E but it sounds like it may need to go back to Asus for repair. Could be a severed soldering point or a small crack in circuit boards. When/if you are able to get it repaired it may not be a terrible idea to think about considering a case.
    Live long and prosper.
  3. #3
    Quote Originally Posted by too lame to come up with a good username View Post
    Why did you go naked?
  1. ***i cant root my device** help**
    By RootaRegg in forum Samsung Galaxy Note 2 Rooting, ROMs, and Hacks
    Last Post: 01-06-2014, 04:24 PM
  2. Reappearing notifications on my phone... HELP!!
    By Rj Pina in forum Sprint Galaxy S3
    Last Post: 12-25-2013, 09:58 PM
  3. Newsie to Samsung Ring but where is it here?
    By jamak in forum Introductions
    Last Post: 12-22-2013, 08:53 AM
  4. HELP! Dropped my N7 and now it won't turn on?
    By too lame to come up with a good username in forum Google Nexus 7 Tablet (2012)
    Last Post: 12-21-2013, 07:23 PM
  5. Att galaxy s4 on tmobile?
    By meow876 in forum AT&T Samsung Galaxy S4
    Last Post: 12-21-2013, 06:32 PM
B
