Results 1 to 4 of 4
    Default Bought Tablet - It arrived with ZERO Charge/Battery Life
    Is this normal? It was literally at Zero %. I actually bought 2 of the same, 1 was at 50% the other at 0%. I've since charged it up and it "seems" to be ok, but I'm considering just returning it for another one just to be safe.
    Thoughts?
    Thanks in advance.
  2. #2
    Golfdriver97's Avatar
    Posts
    Global Posts
    13,909 Global Posts
    ROM
    Stock Moto X
    Default Re: Bought Tablet - It arrived with ZERO Charge/Battery Life
    Quote Originally Posted by Boomax24 View Post
    Thoughts?
    Thanks in advance.
    I would check the return policy. If you have say 14 days, give it a few days and monitor the battery closely. If it seems to drop off with little use, return it.
    Devices: Current: Nexus 5, Moto X, Galaxy Tab 2 (7.0); Retired: Galaxy S2 (Epic 4G Touch); Traded: Galaxy S3
    When I let go of what I am, I become what I might be - Lao Tzu 'If we could change ourselves, the tendencies in the world would also change.' - Mahatma Gandhi
    Community Guidelines and also here
  3. #3
    srkmagnus's Avatar
    Posts
    Global Posts
    6,763 Global Posts
    ROM
    Stock 4.4 (KitKat)
    Where for you buy from? Devices usually come somewhat charged. Though, I'm not sure it could be impossible to receive a perfectly fine device with zero charge.
    Quote Originally Posted by srkmagnus View Post
    B&H. It's odd because I ordered 2 at the same time, and 1 came with half charge the other had zero charge.
  1. Lock/Unlock your mobile with this new app
    By androidsafe in forum Android App Inventor
    Last Post: 03-17-2014, 08:37 PM
  2. It's been out a while, do you recommend 4.3?
    By BobR1908 in forum Samsung Galaxy Note 2
    Last Post: 12-23-2013, 08:25 PM
  3. Battery drain *screenshot*
    By luke318is in forum Android 4.1 / 4.2 / 4.3 Jelly Bean
    Last Post: 12-22-2013, 06:56 PM
  4. I deleted my OS and can't get it back together!
    By thezcool in forum Samsung Galaxy S4 Rooting, ROMs & Hacks
    Last Post: 12-22-2013, 05:22 PM
  5. Customize your personal Virtual assistant with 3D Pal ( 3D Siri )
    By BombAppromotion in forum Android Applications
    Last Post: 12-22-2013, 04:29 PM
B
