Results 1 to 8 of 8
    Question Do we really need battery saver apps?
    Do we really need battery saver apps for android ? I think even they take some battery juice for them to work right? Things like Battery Doctor and Due Battery saver only instruct us to close some apps to features like wifi gprs to save battery right?
    If you are not rooted, they are useless right? Please correct me if I'm wrong
  2. #2
    Darth Spock's Avatar
    Posts
    Global Posts
    5,772 Global Posts
    ROM
    Assassin 'Droid
    Default Re: Do we really need battery saver apps?
    My opinion is that the difference is negligible and they generally do more harm than good to usability, but some people swear by them. There probably are useful aspects that just aren't balanced out for me which they appreciate more.
    ​Obvious statement: Why, I am an assassin 'droid, Master.
    May the Force Be With You
    Community Rules & Guidelines​
    (Formerly "NothingIsTrue")
  3. #3
    No i don't think we do
  4. #4
    KWKSLVR's Avatar
    Posts
    Global Posts
    434 Global Posts
    I say no. I think it's better and more effective to manage your apps efficiently by doing stuff like reducing or turning automatic refreshing off, avoiding shoddy apps, keeping haptic feedback and touch sounds off and being conscious of brightness levels.
    Battery life on Android is mostly all about deep sleep. Trying to put a bandaid over poorly managed apps won't fix that, arguably with the exception of root + an app like greenify and freezing out everything that you aren't using.
  5. #5
    No. Never found one to be of any use at all. Manually managing stuff works fine.
  6. #6
    srkmagnus's Avatar
    Posts
    Global Posts
    6,777 Global Posts
    ROM
    Stock 4.4 (KitKat)
    I don't use a battery monitor app. My opinion is that you know your device best and what you need to close for it to have great battery life. Android has a good built in task manager and will kill processes/services no longer needed.
    That's not to say battery saving apps are a waste. Most do offer useful information to pinpoint what could be causing battery drain, such as a rogue app, or provide actual battery savings if used right.
  7. #7
    Quote Originally Posted by NothingIsTrue View Post
    Exactly. It seemed like when I had a battery saver app on my Optimus G, it didn't do anything whatsoever.
    Sent from my iPhone using
  8. #8
    I use battery defender and it helps me by shutting of wireless networks when the screen is off.
    Posted Via VZW Moto X on the Android Central App
  1. Problem with Samsung's Music App on Galaxy Note 3
    By Dronak in forum Samsung Galaxy Note 3
    Last Post: 02-06-2014, 05:08 PM
  2. Running 2 different apps at the same time???
    By jackdps in forum Google Nexus 7 Tablet (2013)
    Last Post: 12-28-2013, 01:15 PM
  3. App to control WiFi, sounds based on location
    By christianbiker in forum General News & Discussion
    Last Post: 12-28-2013, 08:15 AM
  4. [app][free] multi app starter -
    By Nico Ackermann in forum Android Applications
    Last Post: 12-27-2013, 10:41 PM
  5. *HELP: no voicemail after installing dialer and visual voicemail app
    By rob damiani in forum General Help and How To
    Last Post: 12-27-2013, 05:12 PM
B
